586,108 active members*
3,213 visitors online*
    May 2005
    2502
    New Way Covers for the IH Mill...
    After 4 years I finally decided it was time to replace my way covers. They were cracked, tearing, and generally worn out.
    Home Depot Shower Pan Liner is an inexpensive and very nice material to use as a replacement. Rather than fit it to the existing brackets, I made some new brackets using neodymium magnets. If an interference develops, they just pop off rather than tearing.
    Here are a few pics:
    I may make up a couple more sets of those magnetic clamps. I think they'll be handy for some other things.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Aug 2004
    2849
    It is not elegant looking but it should work well.
    Paul
    Nov 2006
    33
    Not bad! Should work fine. I like the accordion style that is on mine right now but it is starting to unthread itself & come apart. I have been trying to figure out an alternative. Been thinking about using some 1/8" or so thick rubber material. Should be an easy repair & cheap too. Wouldn`t think it would retain chips as bad as the original way cover that is on there now either. That would be a plus. Still pondering.
    May 2005
    2502
    Chips don't seem to stick to this material, and it gets out of the way just fine, so no need for accordion.
    Some day I'd like to build some stainless telescoping covers with parallelogram linkage, but that's a lot of trouble. This was easy!
    Cheers,
    BW
    May 2005
    59
    Hello Everyone,
    I've not made the cover for the z axis yet but here's my covers the the other ways. I used carpet runner. This is pretty handy stuff. You can get it at the depot.
    It's got ribs so it moves differently in each direction. Handy when your trying to get it to work a certain way.
    It's probably much more durable than the shower liner. It's designed for foot traffic.
    I drilled and tapped some holes below the y dovetails in the front of the machine to roll the cover over when the table is near you. You don't have to do this if you don't want to. It just makes it neater.
    Attached Thumbnails Attached Thumbnails runner3.jpg   runner4.jpg   runner5.jpg   runner6.jpg
  1. vf3 way covers
    By mls in forum Haas Mills
    Last Post: 02-03-2009, 02:41 PM
  2. IH way covers
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 09-19-2007, 08:35 PM
  3. Way Covers For SX3
    By Old Megawatts in forum Syil Products
    Last Post: 06-15-2007, 05:03 PM
  4. Haas mini mill tool changer sliding covers?
    By duenow in forum Haas Mills
    Last Post: 07-18-2005, 05:46 PM
