586,121 active members*
3,660 visitors online*
Page 1 of 10 123
Results 1 to 20 of 191
    Feb 2005
    130
    5AXIS: photos - new build
    5 axis machine build
    Working Size: 1500mm x2500mm x1000mm
    Full Size: 2500mm x3500mm x1700mm
    Spindle Motor: Elte 5,5kW + inverter Lenze 5,5kW
    Transmitting System:
    X: 2x (toothed rack + HTD 1:3 translating bar gear + 28Nm stepper motor)
    Y: toothed rack + HTD 1:3 translating bar gear + 28Nm stepper motor
    Z: trapezoidal screw (Self-locking) 3205 + HTD 1:3 translating bar gear + 50Nm stepper motor
    B, C: Angular axes - HTD 1:3 translating bar gears + 50Nm stepper motors
    linear rails on XYZ
    Controlling System:
    6 channels of 2 phase high voltage stepper motor drivers (250V DC)
    2 LPT port as interface for mach3 AND/OR EMC2
    current status of build:
    base:
    assembly:
    50Nm stepper motor
    assembly inside the tent:
    head:
    be continued...
    more about:
    http://forum-cnc.pl/index.php?topic=1148
    http://soltysdesign.xip.pl/forum/viewtopic.php?f=3&t=48
    working TEAM - SOLVO
    BARTUS
    designers, dreamer, mechanician, machinist miller, lathe hand (turner), welder
    http://cnczone.com/forums/member.php?u=175168
    MARKcomp77
    electronic engineer, supplier of stepper motors & drivers, designer of electronic part - control units, wires,
    http://www.cnczone.com/forums/member.php?u=9150
    Jun 2005
    164
    When you have to build your machine in a tent you know you have gone way beyond hobby CNC.
    Thankyou Mark for sharing this awesome project with us all.
    <insert witty comment here>
    derekj308
    Apr 2007
    8082
    Quote Originally Posted by derekj308 View Post
    That there is no hobby build for sure. I like steel builds, but this one has a very serious purpose behind all of this expense and effort. There's some quality design and welding going on under that tent. Maybe this will eventually get moved to a more permanent industrial location.
    I suspect that it will be stiff enough for most of us watchers. I wonder what it will weigh when completed. We need a poll for that, and a piece of scrap steel from the build as a prize for the correct guess.
    Thanks for posting this build here.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Feb 2005
    130
    yes... but DIY work
    This will eventually get moved to a more permanent industrial location.
    yes... it will be moved... or hold out
    about ~3000kg
    When I look at your pictures I can only say - holy crap! that's some awesome piece of gear your building there sir! - very nice!
    Jun 2003
    58
    that's a very interesting machine,
    what will you make with it ?
    CNC Toolkit - Open Source 5-axis CAM utilities
    www.cnc-toolkit.com : code.google.com/p/cnctoolkit : cnc-toolkit.blogspot.com
    Apr 2004
    305
    HOLLY SHNIKIES! That is one heck of a large machine!
    What are you planning to cut with that machine?
    Dec 2007
    379
    Keep the pics coming! This is just too cool.
    Feb 2005
    130
    its for surface treatment of mold (mould) for thermo forming machine (moulding machine)
    Apr 2007
    8082
    Quote Originally Posted by markcomp77 View Post
    yes... but DIY work
    about ~3000kg
    Thanks for your answers Mark. I can only be envious of building something of that scale. 3000 kg = 6613 lb and 13.88 oz = a lot of metal.
    CarveOne
    CarveOne
    Feb 2005
    130
    I will try asap
    mechanical designer - bartuss1
    Apr 2005
    47
    Wow.
    Sep 2008
    18
    Awesome! What is the intended use?
    Jun 2003
    453
    Excellent work gentlemen, I'm looking forward to updates.
    Aug 2009
    392
    That thing is truly amazing. Excellent work!
    Oct 2005
    2392
    I knew it was big... But that picture of bartuss standing INSIDE the machine kinda bumped it from big to BIG...
    This si the first thread I've seen of a guy standing inside the CNC machine he was building!
    Great thread!
    May 2008
    1185
    No comments on the CNC drill press?
    It looks like the drill press did a fairly good job but it does look like it leaves some chatter marks.
    Great job so far.
    Apr 2005
    101
    could it be scaled down?
    Hei - may be this is not just a curiosity for the rest of us...
    I think every amateur CNC'er dreams of playing with a 5-axes machine, but very rarely
    have I seen a working sample here on the zone - the 2-axes rotary head is particularly
    difficult to design...
    But, here we have a professional 5-axes machine, and we might be able to get more info
    on the design. So, would it be possible to scale this monster down to a size that would
    be acceptable for an amateur machine? May be a factor of 4, resulting in 857x625x425mm
    overall, with travel of 625x375x250 - quite nice for a medium-sized amateur machine!!!
    Weight would be about 50Kg (1/64 of the full sized machine...)
    May be some of the geniuses here at the zone could come up with a feasible design - I
    know that not everything scales nicely: the spindle is probably the most troublesome,
    but who knows? Think about it: a real 5-axes amateur CNC router!!!
    Nelson
    Jun 2005
    21
    Great work! Can't wait to see the video and the sound of 7000oz-in stepper motors.
    Here is a nice small 5-axis machine. You could fit a dozen of these in this big monster. I think it is big enough to park the car in it and attach a buff to the spindle and have a CNC car polisher
    May 2006
    2420
    This is a cool build, can't wait to see it in action
    I was wondering...with 5 axis tool zero-ing, do you have to zero the tool twice ?
    Say if you were machining out something like a cup, once the head assembly rotates 180 deg to the other side (I can't explain it any better, hope someone understands) the tool offset (away from the centre point) will have to be known and allowed for to use different length cutters.
    I would imagine you would zero the tool facing one way, then spin the head 180 deg and zero again, then add some kind of offset, or do I have it wrong ?
    Cheers.
    Russell.
Page 1 of 10 123
  1. 5aXis-USB-iso-BOB
    By Yachaan in forum Open Source Controller Boards
    Last Post: 09-20-2015, 05:48 PM
  2. Semi - DIY CNC Router / Mill Project Build (With photos)
    By rescueweasel in forum CNC Wood Router Project Log
    Last Post: 08-30-2014, 06:21 PM
  3. 5axis help
    By BOATDUDEGUY in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2014, 08:08 PM
  4. My CNC build-up with video and photos + everything a beginner should know
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 02-07-2008, 02:53 AM
  5. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
