586,076 active members*
3,870 visitors online*
    Feb 2006
    1792
    poor surface finish
    When I try to turn less than 10 mm dia mild steel rod using a carbide tool (55 deg diamond-shaped, sharp radius), I am not getting good surface finish. It has non-uniform appearance. Any suggestions?
    Thanks.
    Feb 2006
    992
    what's the RPM? how big is toolnose rad? how fast is your feedrate? Milde steel you can try .01fps
    The best way to learn is trial error.
    Feb 2006
    1792
    I have tried several combinations of cutting parameters without satisfactory result. The insert is DCMT 11T304, i.e., with 0.4 mm nose radius. What rpm, depth of cut and feedrate should I use?
    The workpiece is 150 mm long with 10 mm diameter. I have a feeling that there is some vibration due to slenderness of the workpiece.
    Feb 2006
    1792
    Yes. It was because of vibration/sharp nose only.
    I tried 250 rpm and 40 mm/min feedrate, with 0.8 mm nose radius. This gives acceptable finish.
  1. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
  2. bad surface finish
    By tunitime in forum MetalWork Discussion
    Last Post: 10-25-2009, 05:35 PM
  3. Surface finish
    By chakaloso in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2007, 02:54 AM
  4. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
  5. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
