586,581 active members*
2,686 visitors online*
IndustryArena Forum > CAM Software > CamBam > Is Mach3 best/only choice with CamBam?
    Feb 2010
    Hi all. Newbie, here. I'm finally plunging into the CNC world and will start with using CamBam as I've read good things about it and the price is right. I know that it was designed to work with Mach 3. My stepper motors will be driven by a Gecko 540. Is Mach3 still the best choice for a windows OS?
    Feb 2010
    Talking cambam/mach 3
    You may want to look at www.kellyware.com Kcam4 is pretty neat.Works well with cambam
    Feb 2005
    521
    CamBam plus has a post processor system which can be user customised to produce g-code for a variety of CNC controllers.
    Mach3, TurboCNC, EMC and Fanuc post processors are included in the standard install.
    www.cambam.co.uk
    Jan 2009
    Smile
    I use CamBam with EMC and they work quite well together. You can go to http://linuxcnc.org/ and download a "live CD" that you can boot your PC from and try out EMC without making any changes to your computer.
    Good luck,
    Mike
    P.S. I almost forgot, EMC and Linux are FREE!! :-)
  1. cambam problem
    By smitty9306 in forum CamBam
    Last Post: 10-04-2009, 05:43 AM
  2. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  3. Need Help With CamBAM
    By Ponchibego in forum CamBam
    Last Post: 08-01-2008, 03:49 AM
  4. cambam and Turbocnc
    By wantsout in forum CamBam
    Last Post: 10-15-2007, 09:15 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
