586,379 active members*
3,561 visitors online*
IndustryArena Forum > CAM Software > OneCNC > OneCNC mill/turn with C+Y+B axis module
Results 1 to 9 of 9
    Apr 2003
    1357
    I'm wondering if anyone uses this software with the Mazak Integrex machines? We are in the process of buying one, and I need to shop for software.
    What we are hoping to do is turn and mill pre-hardened material (60Rc-62Rc) to fairly tight tolerances (±.0002"). So far it seems like we are heading in the right direction with the machine, but as far as software goes, I'm still not sure. We use WorkNC for programming our 5-axis mills, but they don't have a lathe module yet. I've priced some software, but it's hard to justify the cost for relatively simple pieces (I'll attempt to attach a picture)
    I e-mailed them with some questions, but haven't heard back. I'm not ready to either initiate conversation, or demo software yet as it's early in the process.
    Does anyone have an idea of the price? I just need a ballpark figure for now.
    Based off of the illustration, is it reasonable to expect OneCNC to handle these? Machining would use both spindles, can OneCNC handle that?
    Dan
    Feb 2006
    992
    Never have OneCNC for Intergex. It was three years ago..... they give us a quote for lathe module is $3200, but that is mill/turn not Intergrex and I assume the Intergrex post will be sold seperate, the post can be expensive.
    My recommend you should look at Esprit DP technology, their specialty is Intergrex or simular configuration machine, and I know the intergrex post is come with the software. Draw back is it's more expensive than Onecnc. FeatureCAM is another one you should look at, not pricey and can do the part you asked.
    The best way to learn is trial error.
    Apr 2003
    1357
    Thanks for the response. Esprit is actually one of the programs I'm looking at.
    Dan
    Jan 2004
    539
    That might be the understatement of the year as we looked at them pretty hard. That said, the software is the cheap part of one of these machines.
    Here is a layout card I got before I got my seat of OneCNC. It shows their turnmill module.
    Gary
    edit; the pdf is too big to attach here :bs:. If you want send me a pm with a email and I will send it..
    Apr 2003
    1357
    PM sent.
    Dan
    OneCNC does not charge for post processors. You can create, edit any post or contact any OneCNC office for your post requirements. Why don't you just contact one of our offices and investigate this further?
    Apr 2003
    1357
    I thought that's what I did when I sent the e-mail (which to date has had no response)?
    Dan
    Talking
    Dan,
    Hello, if you would like, when you are ready, contact us (OneCNCWest) and I will personally find the answers for you.
    Apr 2003
    1357
    Sounds good, thanks.
    Dan
  1. RFQ - Program Emco 7 Axis Mill/Turn
    By C5Frenzy in forum Employment Opportunity
    Last Post: 09-19-2009, 04:48 PM
  2. Haas 4th axis live turn and mill.
    By Sam Mcquern in forum GibbsCAM
    Last Post: 04-23-2009, 02:32 PM
  3. c axis feed rate on a turn /mill machine
    By bike in forum G-Code Programing
    Last Post: 09-30-2008, 12:57 AM
  4. Will X2 support mill /turn multi axis lathes?
    By bassn_07 in forum Mastercam
    Last Post: 04-27-2008, 12:58 AM
  5. Replies: 0
    Last Post: 04-22-2008, 07:20 PM
