Hi, im new to this forum and have just installed mach 3 on my computer for my cnc step high z s720. previously i was using Win PCNC but decided to change to Mach 3 as i really liked the 3D display and the easy of control and use. i had some problems setting it up but eventually got it moving.
im still left with some problems though...
i decided to run some codes that i had previously used with PCNC using the same vice and exact location that i would have used before, but i noticed my starting origin was different to my previous origin (i had a hole drilled in the exact co-ordinates of 200,210) and when i moved the tool to that location with Mach 3, the tool was off, it seems near enough in the x axis but my y axis seems off by nearly a mm id say, i no this doesnt seem a lot in the grand scale of things, but the work i do is very precise and needs to be spot on every time.
what seems to be the problem and is there any way to fix it? please say i dont have to go back to using PCNC for this work?
Marian
