586,080 active members*
3,526 visitors online*
    Dec 2009
    82
    Random question about Face Mill angle
    I saw this add on Shars Tooling Website: http://www.shars.com/.
    http://www.shars.com/products/view/7...ll_SEHT_Insert
    It made me wonder why a 45* set angle for cutters would have increased feed rates over a 90* set angle. Seems like it should be the same.
    Sorry, random question. >.<
    Anyone know though?
    Aug 2009
    684
    Face Mill Approach Angle
    A 45deg approach exerts less radial pressure on the workpiece than a 90deg approach, so you will find you can plough through quicker without as much shrieking (from the cutter that is).
    It does, however, exert more axial pressure, so make sure the workpiece is secure!
    Have just started having some experience with Feed Mills. The very shallow lead angle means you can feed at about 1mm to 1.5mm per tooth per per rev. Downsides are you can only cut about 1mm to 1.5mm deep (and you don't get much warning of your cutter about to explode). They seem to work best when fully-engaged, eg helical milling.
    DP
    Jul 2007
    1602
    Check out http://www.cnccookbook.com/CCBlogOct2009.htm see the section called Sturz Milling and Other High Tech Milling Tricks"
  1. R8 face Mill Question!
    By QSPSB in forum Benchtop Machines
    Last Post: 12-22-2009, 07:42 AM
  2. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  3. Face Mill Insert Question
    By ImanCarrot in forum Uncategorised MetalWorking Machines
    Last Post: 06-04-2008, 04:00 PM
  4. Replies: 7
    Last Post: 01-22-2007, 02:56 AM
