586,096 active members*
3,821 visitors online*
IndustryArena Forum > CAM Software > Vectric > Rotary Tutorial for Aspire & V-Carve
Results 1 to 8 of 8
    I'm putting together a tutorial on rotary machining with Aspire and V-Carve. It is a work in progress that I hope to have completed by March 2010.
    http://www.222artisans.com/Rotary/RotaryTutorial.HTML
    Dec 2004
    1316
    Excellent resource, thanks rcnewcomb.
    Jason
    rotary on cut3d?
    I presume that cut3d works on the same engine as the other vectric titles. Then, may I assume that the rortary gadget could also be applied within cut3d? That would be neat.
    cheers, Maarten Visser
    Cut3D does not support a rotary axis.
    I've updated the tutorial and included examples for a Y mounted indexer. Please review these. When they are satisfactory I'll generate a set for X mounted indexers. Please review at:
    It looks like things are stable enough that I can start translating some of the Y axis examples into examples that will work with X mounted indexers. I hope to have that done by the end of next week.
    I enjoyed meeting others at Jim McGrew's Aspire gathering this past weekend.
    A copy of the PowerPoint I used for the talk on "Designing For Rotary" is available at:
    http://www.222artisans.com/Columbia/...gForRotary.ppt
    I tried to include material for non-rotary users so they could see how to take round designs and use them for flat machining.
    I did NOT use every slide. That would have been death by PowerPoint, but I wanted to be prepared for questions regarding some of the rotary gadgets.
    Thanks for sharing that.
  1. aspire and cabinetmaking
    By cabnet636 in forum Vectric
    Last Post: 06-28-2009, 02:50 PM
  2. Replies: 1
    Last Post: 03-13-2009, 09:36 AM
  3. Aspire!!!
    Last Post: 02-23-2009, 06:15 PM
  4. 15 minute Aspire?
    By bsimages in forum Vectric
    Last Post: 01-30-2009, 02:51 PM
