586,594 active members*
2,890 visitors online*
    Stainless Steel
    Can I get a little help with some settings for Stainless Steel 10 and 12 ga?
    I am using the 40amp fine cut consumables....Hypertherm 1650 set at 45 amps. getting a real ragged cut with lots of slag. Very sure it is a simple adjustment to make this better.
    Thanks!
    Dec 2009
    35
    I can't offer any real help other than saying go by the settings in your 1650 manual but if you post this down in the Hypertherm forum Jim Colt from Hypertherm will be all over it and get you dialed in quick.
    Thanks...will do.
  1. 303 vs. 304 stainless steel
    By pearldiver in forum MetalWork Discussion
    Last Post: 02-06-2020, 08:45 AM
  2. Stainless Steel
    By jdclark in forum Shopmaster/Shoptask
    Last Post: 02-25-2009, 05:08 AM
  3. Steel or Stainless
    By tool_man in forum Casting Metals
    Last Post: 10-29-2006, 12:46 PM
  4. Stainless Or Steel
    By 69owb in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 07:43 PM
  5. Is stainless steel
    By cncadmin in forum Hard / High Speed Machining
    Last Post: 10-17-2003, 02:19 PM
