586,602 active members*
3,434 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Cincinnati Milacron Arrow 750 Error Message
Results 1 to 7 of 7
    Feb 2010
    Exclamation Cincinnati Milacron Arrow 750 Error Message
    Hi Everyone, I am a bit new to this - so I hope you can help?
    Got the following error messages on my Arrow 750 machine:
    1) C axis reconfiguration failed
    2) C axis enable signal set on but C axis ready signal not been received.
    I know the problem is to do with the spindle and I guess some sensor or wiring has broken.
    Any ideas where I should start looking.
    Regards
    Nikon Phil
    Nov 2005
    172
    My geuss is that this is an error you get when trying to switch from 2 axis turning mode to 3 axis milling mode? If so...there should be a clamp that engages the spindle to act as a "brake" and control indexing and such. I would start there, there will probably be a sensor that tells the control which mode you should be in and if it is or isnt in that mode.
    Hope this helps!
    MArk T.
    Jan 2008
    7
    What control is on the arrow. I had problem one time when the machine was trying to tool change the spindle was juddering and could not align the drive dogs so that it would accept the tool and it came up with the same error. This was on a heidenhain control and I ended up having to change the Kollmorgen spindle drive unit. I hope this helps but I hope its not that as they are not cheap.
    Regards Reidmans
    Nov 2005
    172
    I believe the Arrow I was running years ago had an Acramatic control...nice little control as I remember...had some good conversational features.
    Mark T.
    Sep 2008
    66
    prox switch
    Quote Originally Posted by Nikon Phil View Post
    Regards
    Nikon Phil
    i had this happen a couple of weeks ago
    is your mill equiped with the high torque spindle and a A2100 control?
    this is what i did with mine
    i took the cover of the Z axis (motor/spindle) assembly and had a look down from the top at the belt drive gear on the spindle, there is a prox switch that points down at the gear. the prox switch was not sensing the raised part of the gear. SO... before i changed it i followed the wires back to the COLTOR BOARD (large green circut board inside on the right of the electrical cabinet).
    thinking it way be just a dirty connection, i disconnected the plug (R29 on my machine), blew it out and reconnected it. rebooted the mill and aligned it.
    haven't had a problem since.
    if that's not it, you may be able to get away with changing just the switch
    Hopefully it's not a broken wire to the switch - looks like a real dog to change!
    hope this helps
    Good luck
    Mac :cheers:
    Nov 2005
    172
    When the original post referenced the spindle and "C" axis...I was assuming this was a 3 axis lathe. I can not remember if the Arrow model was a lathe or mill. If it is a mill, then the C axis would probably be referencing an indexer. In which case my geuss would be a bad wire / prox. Sorry for nay confusion I may have casued in the post!
    Mark T.
    Feb 2011
    Hi I had this error pop up Cincinnati milacron error code 9170 status 1 z axis not available. I was drilling at the time :S
  1. Cincinnati milacron arrow 500
    By shmoo in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2014, 10:33 PM
  2. Cincinnati milacron arrow 500 to pc
    By gazzaa in forum Want To Buy...Need help!
    Last Post: 01-20-2012, 07:30 PM
  3. cincinnati milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2009, 08:26 PM
  4. Replies: 1
    Last Post: 09-12-2008, 08:42 PM
  5. Cincinnati Milacron Arrow 750 Serial Port
    By kirkmachine in forum DNC Problems and Solutions
    Last Post: 09-21-2007, 03:38 PM
