586,551 active members*
3,562 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Orbital Vibration Welding or Another Method?
    Apr 2003
    1876
    I'm trying to weld stranded wire to a Honeywell thermal switch (over-temp safety switch).
    Can't solder it. Can't spot weld it. I've heard orbital vibration welding might be the way to go, but don't have much info on it.
    Also, what are battery packs welded with? The connectors to those are much less delicate than what I'm trying to weld, so what ever they're using might work for the thermal switches.
    TYIA.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Nov 2009
    4415
    Are you referring to "Friction stir" welding?
  1. Orbital Drilling
    By Mohan in forum MetalWork Discussion
    Last Post: 01-05-2010, 10:58 AM
  2. TIG welding Steel/Iron welding with Argon?
    By Rich05 in forum Welding Brazing Soldering Sealing
    Last Post: 12-02-2007, 02:11 AM
  3. Any source for an orbital action spindle??? rod chamfering?
    By InspirationTool in forum Mechanical Calculations/Engineering Design
    Last Post: 06-04-2007, 04:16 PM
  4. Global Warming: The Orbital Solution
    By dillyh in forum Environmental / Alternate Energy
    Last Post: 04-19-2007, 12:41 PM
