586,075 active members*
3,871 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Need help, regarding interfacing of NC Milling Machine with PC
Results 1 to 7 of 7
    Feb 2010
    Smile Need help, regarding interfacing of NC Milling Machine with PC
    Hello everyone,
    I am interfacing a vertical NC Milling Machine with PC through a serial cable. i am using NCnet Lite(Version7) software for transfering data. Following is the machine information:
    Shizuoka Vertical NC Milling Machine (3-axis)
    Model no > Mill Master AN-S
    Controller > Fanuc (System 6M)
    How can i set the baute rate, parity etc of machine?
    Machine is provided with 25 pin female port and PC with 9 pin male port.
    Problem statement:
    When i connect the serial cable between Machine and PC and test the serial port through NCnet Lite software. the following message appears:
    Test Result
    DTR/DSR Signal ok
    RTS/CTS Signal ok
    Communication at baudrate Testing
    COM1 is not ok at the baud rate 600
    COM1 is not ok at the baud rate 1200
    COM1 is not ok at the baud rate 2400
    Thanx for your time
    Jul 2004
    173
    Have you confirmed the comm port on your PC?
    Look in the device manager and see what comm port is there.
    The check your RS232 cable that you have interfaced to the machine to the PC. Send a file from the CNC back and see what the results are. You will probably just need to tweak the software to match the settings if you don't have the manual.
    Need more help, give me a call.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    24221
    This is the cadem file for the 6.
    I generally use a 3 wire cable with the hardware H.S. jumpered out.
    Al.
    Attached Files Attached Files
    Albert E.
    Feb 2010
    Thanx gm3211
    Quote Originally Posted by gm3211 View Post
    I have interface the machine with PC. Problem was there in matching of baud rate of machine and PC. thanx for the help.
    Now i need to increase the memory of machine for reading of blocks. Machine can only 500 blocks. Do you have any idea, how can i do that?
    Feb 2010
    Thanx Al The Man
    Al.
    Pdf file was very helpful. I have interface the machine with PC. Problem was there in matching of baud rate of machine and PC. thanx for the help.
    Jul 2004
    173
    You can use a BTR card to DNC to the machine which will provide unlimited memory.
    Jul 2006
    98
    Have you considered converting the machine to a modern controller (EMC2, Mach3, Flashcut, etc.)? I can appreciate that if the machine is working for your needs, then it doesn't need to be fixed. On the other hand, if you are going to use the machine beyond the near future, you may be better off converting, especially if you can do most of the work yourself. Just a thought.
    Kirk Wallace
    http://www.wallacecompany.com/machine_shop/
    http://www.wallacecompany.com/E45/index.html
    California, USA
  1. Interfacing stepper motors with computer
    By John DiBernardo in forum CNC Machine Related Electronics
    Last Post: 06-01-2010, 03:19 PM
  2. Picstep working but trouble interfacing to PC
    By gtrdude in forum CNC Machine Related Electronics
    Last Post: 08-30-2009, 03:28 PM
  3. interfacing rhino ST6 lathe
    By albert5 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-08-2008, 10:50 PM
  4. Darlinton array for interfacing limits?
    By Greolt in forum CNC Machine Related Electronics
    Last Post: 02-13-2007, 08:07 PM
  5. Makino Interfacing
    By Professorwiz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2005, 04:54 PM
