Need Set Up Help - I Have a Qt18-ms I want to turn a shaft 240mm long 15mm dia. using the sub spindle to support the end and sink both chucks can this be done or is there a easier way for shafts on this type of mazak?
If you can turn a cylindrical portion at the first feed out to grab you should be OK.
turn short O.D. at Head 1
Grip turned dia with Head 2
Pull out stock full length with Head 2.
Synch both spindles - I think this can be done at the beginning?
Turn O.D. wiht both spindles synched.
cut-off without a lot of revs at blade break through.
pretty sure everything is possible with the enlightened use of mazatrol transfer units?
-jim
I have same kind of machin and i don't know how to set manyal the tools
the tool eyw is not working
coud you help me?
