Hi All,
does anyone know of a supplier of off the shelf thread mills, 40 tpi, with a 55 degree whitworth form, perferably in the uk.
Thanks in advance
Paul
Hi All,
Thanks in advance
Paul
I have on occassion, taken a mill that was half the thread count (i.e. 20 tpi) and made two passes. Not horribly efficient, but functional for a few parts.
ehhh, nm, wasn't thinking of your thread form, bad advice
If you have a single toothed thread cutter, you can have any tpi with it, though the process would be less efficient.
OD or ID thread and what size.
If it is OD you can cut just about any size using a lathe threading tool in the spindle, but as mentioned it is not efficient.
You can also mill internal threads using a latge tool but then your ID has to be larger than about 1" because the tip sweeps out a circle larger than the bar it is mounted on.
If you can't find a supplier, you could try what JustGary did in this thread.
Larry O
