586,047 active members*
3,621 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Removing table on Super Minimill
    Feb 2010
    I just bought a used super minimill, and since it is not here yet, I was wonding if anyone had taken the table off. I want to replace the table with a pallet pad for my Erowa pallets. Anyone done this?
    Aug 2006
    259
    Wouldn't it make a bit more sense just to make an adapter plate? or would you loose too much in your Z travel?
    Just when you thought you had it all figured out, all hell breaks loose..
    Feb 2010
    extactly. I dont want to loose any z travel. I am not sure if you can add the riser to exsisting machines, and if you do a riser, plate then add the pallet height, and fixtures / vises etc you loose. I do have pallets for the rotary tables already made from the old machine, and makes setups a 1 minute ordeal. I was looking more if the table is on a saddle or if the bearings are integrated into it. i noticed it has a hole pattern in the top. I may just give Haas a call any wya as I need to order a 5th axis card and wiring for the machine.
    Aug 2006
    259
    If I get a chance today, I'll look at the maintenance book, but yea, calling the HFO would work too, their usually very helpful.
    15362
    MKproto
    The hole pattern that you can see on the table is were the ballscrew nut mounts, you do have a extra 4" of Z travel above tool change that you can use, you just have to program it right,for the Z to go up after a tool change to clear your work if you have long tools or need more clearance, & I think the Zaxe riser block is factory fitted only,The machine is 13.5 of Z travel, that is from tool changer Z0 to the table, you have another 4" above this that can be used making it 18" from the table to the bottom of the spindle, the spindle stops 4'' from the table
    Mactec54
  1. Removing 4th Axis from Table, Fanuc 0i
    By Jay Kyle in forum Fanuc
    Last Post: 08-10-2022, 03:04 PM
  2. Super MiniMill Vise/Rotary Changeover
    By Geof in forum Haas Mills
    Last Post: 01-05-2010, 06:49 AM
  3. Removing Table on Smithy 1240
    By bgulari in forum Smithy
    Last Post: 11-15-2008, 08:43 PM
  4. Crash reishaw Probe on Super MiniMill using IPS
    By Gus-Gus in forum Haas Mills
    Last Post: 11-01-2008, 04:16 AM
  5. Super MiniMill repair
    By philipm in forum Haas Mills
    Last Post: 12-11-2006, 02:06 AM
