586,842 active members*
3,381 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Help setting work shift offset in LX3 ?
    Aug 2004
    309
    I am not quite grasping how the work offset is set with the LX3 controller.
    In my other turning centers you simply bring the tool up to the end of the stock , touch the end of the part , and press the work offset button and the values are entered .
    Could someone give me an Idiots primer on setting work offset with the LX3/kt15?
    Aug 2004
    309
    I press the offset button and go to the workshift page. The value in X is 10.6. I can enter z** and the offset will change to whatever value is entered at ** . Why cant the X be changed ?
    Mar 2010
    Smile
    On the LX3.. to set the Z axis offset after touching off front of part:
    Use P0 then input
    This will set the zero automatically.
    Also, if you touch off the front of the part and want to set the machine to take off .010 off the face, you just input P.010 and it will automatically set the Z in .010.
    As for your other post, the x axis can only be changed in the parameters.
    We have had these machines for about 15 years and never had to change the "x" axis.
    Hope this helps
    Sep 2010
    86
    The workshift of the X axis doesnt change, since the X0 is the center of the spindle.
    Sep 2010
    86
    The X0 doesnt change since its located in the center of the spindle.
  1. System Variable Z Work Shift
    By ggborgen in forum Parametric Programing
    Last Post: 11-26-2009, 06:57 AM
  2. work shift
    By teamus in forum Hardinge Lathes
    Last Post: 06-10-2009, 11:32 AM
  3. c axis work shift
    By Atlas_Too in forum Fanuc
    Last Post: 10-13-2008, 06:14 PM
  4. Setting Z axis with G92 work shift
    By venomgrrrl in forum Fanuc
    Last Post: 12-03-2007, 06:02 PM
  5. offset shift and part off
    By nitemare in forum Daewoo/Doosan
    Last Post: 03-04-2006, 04:49 AM
