586,075 active members*
4,228 visitors online*
Thread: 48V Relay
Results 1 to 8 of 8
    Mar 2008
    195
    48V Relay
    Does anyone have a source for a 48 volt dc input relay?
    Oct 2009
    28
    24221
    What contact current? How many contacts? Relay or Contactor? Solid State or Mechanical?
    What is the end use for?
    Al.
    Albert E.
    Mar 2008
    3655
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Mar 2008
    195
    Thanks for replying guys.
    I found one and ordered a couple today. Here are the specs:
    Code:
    These relays are ideal for use with the Gecko G540 when using a 48V supply.
    These can be used without the need for an additional relay coil power supply.
    * Contact Form: SPST
    * Contact Rating 20A (Max)
    * Coil Voltage 48V
    * Coil Resistance 2304 Ohm
    * Contact Voltage 240Vac (Max)
    * Contact Voltage 28Vdc (Max)
    * 0.25" spade connectors for Relay Contacts
    * 0.187" spade connectors for Coil Contacts
    I'll post the link here for others members in the same situation...
    http://homanndesigns.com/store/index...products_id=88
    Mar 2011
    Quote Originally Posted by tulsaturbo View Post
    Code:
    * Coil Voltage 48V
    48V 20A Panel Mount Relay [RL-04] - US$8.50 : Homann Designs, The Preferred CNC Component supplier
    Just got a couple of relays like this, except they're 30A.
    I'm building my 1st router and have all the electronics working with a Gecko G540, Keling 48V 7.3A power supply (going directly to the wall), and 3 Keling 3.5A steppers.
    Curious about the router and vacuum <-> relay connections. I checked one of the homann wiring diagrams and it looks like all that is needed to connect the router & vacuum to their respective relays is a female socket, and that the relays/router/vacuum all get their power from the same power supply that the G540 & stepper's connect to. Is this correct?
    Thanks everyone for the help.
    Jan 2006
    738
    Tulsaturbo,
    If you are planning on controlling the router and vacuum from G-code, then the output from your breakout board to the relay coil may need buffering. Does your BOB have relay's on board?
    By the way, I'm in BA if you are in Tulsa shoot me a PM.
    Steve
    Mar 2008
    195
    Quote Originally Posted by vger View Post
    Tulsaturbo,
    Steve
    Hey Steve...
    Yup, I'm located in Broken Arrow now over near the Forest Ridge Golf Club.
    My Blog
    http://www.needfulthings.net/tulsaturbo/myblog/index.php
  1. RPC with a relay
    By Shanghyd in forum Phase Converters
    Last Post: 06-30-2009, 12:02 PM
  2. relay
    By cueshark in forum CNC Machine Related Electronics
    Last Post: 02-18-2008, 07:33 PM
  3. keep relay
    By guhl in forum Fanuc
    Last Post: 08-17-2007, 01:22 PM
  4. Another relay ?
    By Bear in forum CNC Machine Related Electronics
    Last Post: 11-24-2005, 12:31 AM
  5. Need Relay help...
    By CarveJunky in forum CNC Machine Related Electronics
    Last Post: 07-20-2005, 02:52 PM
