hi all , thanks in advance for your help. i have a jet jmd-18pf mill and jet 9x20 lathe . both have served me well for 10 or so years my problem is with the start stop switch on the mill . sometimes when you start the machine it shuts back down when you release the start switch . it used to only do it once in a while but recently it has been doing it alot . you have to hit stop and back to start again to get it to stay running . sometimes several times in a row. it is such a pain . i know the obvious thing would be to check the wiring then if wiring is secure buy a new switch or restore switch if possible . but before i tear into it , i wanted to know first if there is any issues with these switches on the jet machines and if any one has had similar problems . and if i need to get a switch which kind would be best and most importantly what would the specs of this switch be so i can search for a switch with granger etc. i dont mind relocating switch or mounting a control housing on the machine. what would you guys do ??? i dont think i want to pay alot for an exact replacement switch from jet if it is a lower quality switch. especially if i can get a higher quality setup for the same dollars . thanks again bill
