586,465 active members*
3,844 visitors online*
IndustryArena Forum > CAD Software > Solidworks > SimulationXPress with Glass Fibers as material, problems!!
    Nov 2006
    85
    Hello people.
    I want to do some evaluation in SW using the SimulationXPress, the part I want to simulate is made out of glass fiber. But I can`t do the simulation because solidworks don`t have enough values on the different properties of the glass fibers. How can I put in these missing values into SW?
    Nov 2006
    85
    Isn`t there anybody who have made stress simulation with glass fiber as material?
    Aug 2006
    259
    Probably not here Sperstad.. Your best bet would be to hit up the forums on the solidworks site. https://forum.solidworks.com
    Just when you thought you had it all figured out, all hell breaks loose..
    Nov 2006
    85
    You`re probably right, I will try that!
    May 2007
    312
    You might not have any luck since the glass fibers might require fracture probability and Von Misses does not address that. I have never done any work with glass fibers, this is just a guess on my part.
  1. Glass
    By DLMACHINE in forum Glass, Plastic and Stone
    Last Post: 10-10-2014, 05:57 PM
  2. Coupling Stepper With Rigid Material - Any Problems?
    By Brenck in forum Mechanical Calculations/Engineering Design
    Last Post: 08-09-2009, 04:28 AM
  3. SimulationXpress Displacement (mm)
    By suzukirmz in forum Solidworks
    Last Post: 07-13-2009, 10:34 AM
  4. Help with Glass
    By mermaid1015 in forum Glass, Plastic and Stone
    Last Post: 05-12-2009, 04:08 PM
  5. Mounting rails on glass - how flat is glass?
    By Swiss in forum Linear and Rotary Motion
    Last Post: 07-25-2008, 08:10 AM
