586,043 active members*
3,643 visitors online*
Results 1 to 3 of 3
    Sep 2009
    22
    Straightening Acme lead screw?
    Hi all,
    I have just about finished my first CNC machine and received the Acme screws from the USA today. Both screws (36") have bends in them of about 1/4"- 1/2" over their span. What is the best method i should use to straighten them evenly, and will their accuracy be affected? Or am i just worrying too much?
    Thanks kindly in advance,
    Julian.
    Ps. I will post some photos soon of my machine
    35538
    If they don't whip, then you don't need to worry about it.
    Mine were whipping, so I layed them on a flat surface, and rolled them back and forth to find the bends. Then I carefully bent them by hand. They ended up having more smaller bends, but getting rid of the major bends reduced the whipping considerably.
    May 2008
    1185
    I had to straighten mine and I had good luck putting them on the mill with two v blocks and an indicator in a drill chuck with the 3/8 shaft going through the indicator mount so I could use it as a press.
    I used the quill and the shaft to bend the rod straight after I found the high spots.
    I set the v blocks about 6" apart and turned the rod to find the highest spot and then pressed it a bit with the 3/8 shaft in the drill chuck.
    I was able to get a 1/2" bend down to about .010
    A drill press would also work for this.
    They bend easy so be careful.
  1. Acme lead screw 1.5 meter up
    By osix in forum Want To Buy...Need help!
    Last Post: 04-16-2008, 04:57 PM
  2. Acme Lead Screw Questions
    By Eurisko in forum DIY CNC Router Table Machines
    Last Post: 03-26-2007, 11:19 PM
  3. acme lead screw
    By swarfmacdaddy in forum Linear and Rotary Motion
    Last Post: 12-11-2005, 02:09 PM
  4. Acme Lead Screw Decision
    By js15 in forum DIY CNC Router Table Machines
    Last Post: 07-20-2005, 08:44 PM
  5. acme lead screw article
    By sdwilson in forum DIY CNC Router Table Machines
    Last Post: 12-14-2003, 07:33 AM
