G02 but X Y Z movement
I need to machine (mill) a circular groove but it requires a 3D movement, something like a G02 but on a slanted vertical plane, its an helicoid.
Look at this photo:
On top is the unmachined part, bottom is what I need to do and in the middle thats the part that rides on the machined part, its for a steering mechanism, I was not given further details.
The simple solution would be to put the 4th axis at the same angle needed for the cut and then selecting the plane and make a simple G02 movement, but I anticipate that setting the 4th axis at this angle would be a royal pita.
Is there a gcode for this movement or I need to interpolate little segments till I get the desired 3D curve?
Thanks!
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
