586,089 active members*
3,709 visitors online*
Results 1 to 7 of 7
    Apr 2005
    21
    Power Supply - Question
    Does anyone know who makes a power supply for the following stepper motor?
    Holding torque-Nm (oz/in) +/- 10% 8.7 (1208)
    Rated voltage 2.7
    Rated current per phase (amps DC) 6.0
    Resistance (Ohms) +/- 10% 0.45
    Induction (mH) +/- 20% typical 5.1
    Motor length (mm) 118
    Rotor inertia (g-cm^2) 2700
    Weight (kg) 3.8
    Just about any power supply will work. It really depends on how many motors your using, and what drives your driving them with.
    Apr 2005
    21
    Gecko drives. Problem is finding a power supply rated for the 6 amp motors.
    746
    Go with a rewound microwave transformer or a torroid. Microwave transformers are very inexpesive but torroids will cost you a little more but they can be customized also.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Apr 2005
    21
    I'm looking for a power supply that's off the shelf. Not home made.
    With 3 motors rated at 6A each, you only need at most a 12A supply. How many wires do the motors have, and how are you wiring them? 8 wire motors wired bipolar series would possibly only need a 6A supply. Check out the Gecko White Papers at their website, it explains a little bit about what size power supply you need.
    Apr 2005
    21
    I'm using 4 motors. Two wired parallel, to drive X axis gantry. They are bipolar 4-wire.
  1. Power Supply Question
    By BobLWeiss in forum Stepper Motors / Drives
    Last Post: 04-17-2005, 08:27 PM
  2. Power Supply ground question
    By chas in forum Gecko Drives
    Last Post: 04-16-2005, 12:48 PM
  3. FNG Power Supply Question
    By SteinAir in forum DIY CNC Router Table Machines
    Last Post: 01-01-2005, 04:31 AM
  4. Yet another power supply question!!
    By chas in forum CNC Machine Related Electronics
    Last Post: 09-17-2004, 05:49 AM
  5. i got a power supply question
    By ljoe1969 in forum CNC Machine Related Electronics
    Last Post: 01-12-2004, 06:19 AM
