586,379 active members*
3,761 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > 1/5 scale Corsair tank
Results 1 to 10 of 10
    Jul 2004
    36
    My first foray into the world of CNC is this simple tank mold. I drew them up in Rhino and generated the G code in Visual Mill. My good friend Butch Sickels cut them on his CNC router in blue foam. One layer of glass, then filled and sanded out and mounted on a layer of 1/16 G-10 laminate to serve as plugs for producing female molds. The molds were made over the plugs in layered fiberglass and when separated we have matching mold halves. I've never had parts that would fit in either mold before. I think I'm gonna like this CNC thing!
    Tanks measure 24 inches in length and were for napalm.
    Paul
    Attached Thumbnails Attached Thumbnails DSC02039 (Small).JPG   DSC02044 (Small).JPG   DSC02046 (Small).JPG   DSC02050 (Small).JPG
    May 2004
    34
    very nice!!! how about some pic's of the plane!!
    Jul 2004
    36
    Harvard,
    Sorry I didn't build the plane - a buddy named Lee Rice did. I'll see if I can get some photos if you'd like.
    Paul
    Apr 2004
    24
    Opens the window to all kind of projects doesn't it.
    I assume you considered making the mold in one step, what made you deside not to.
    Steve
    Jul 2004
    36
    Steve,
    I did think about just cutting a mold into a block of suitable material but wanted to "keep it simple" for the first go 'round. Also, when I get around do doing large fuselages I'll probably machine the plug parts and build up the female mold. That way I can assemble a larger plug from CNC'd parts which would be cumbersome or impossible to do on the size machines I'll have access to. And one has to be diplomatic when borrowing time on a friend's machine.....
    Paul
    Apr 2004
    24
    If Butch gets busy and you really need to do something your welcome to try my machine.
    Steve
    Feb 2005
    921
    Looks good, what kind of router bit did you guys use in the foam?
    Jul 2004
    36
    We used a 1/2 inch end mill. As you can imagine it cuts like butter at high speed. Great for stuff like this where you will build up a finish on the foam.
    Dec 2004
    84
    Did you use a commerical or DIY router?
    Mike
    Jul 2004
    36
    Mike,
    It was done on a commercial router made by a small local builder. It's a stepper motor setup with a 4 X 8 foot table that my friend uses for his model building company.
    Good to have friends who let you play with their toys.
    Paul
  1. plasma water tank
    By snaggletto in forum Waterjet General Topics
    Last Post: 06-17-2006, 01:04 PM
  2. 5th scale RC CNC Parts project
    By studysession in forum Hobby Discussion
    Last Post: 03-09-2005, 11:37 PM
  3. 1/5 scale Model A engine
    By woodythx13 in forum I.C. Engines
    Last Post: 12-17-2004, 09:16 PM
  4. RFQ closed - scale model machined auto wheels needed
    By joemartins in forum Employment Opportunity
    Last Post: 10-27-2004, 02:16 PM
  5. Very Basic Scale DXF Question
    By awm in forum BobCad-Cam
    Last Post: 01-07-2004, 05:11 PM
