586,112 active members*
3,182 visitors online*
Results 1 to 9 of 9
    Nov 2009
    24
    battery backup
    Is there a battery backup for a VMC15 for the cards, because I keep getting a memory error, and have to go in and clear memory and reset all the parameters.
    900
    There is a lithium battery on the 1400 CPU board. That is the only battery in the Fadal control.
    Neal
    Feb 2008
    547
    Neal,
    What is the proceedure for changing this battery?
    Steve
    Mar 2010
    battery
    I think you just take the cpu out and swap the battery then reload the memory as usual.if you have a memory expantion board take it off and then zero the memory and see if it helps,those boards fail a lot and cause memory issues,if you are concerned about the battery take out the cpu and test the voltage the battery looks like a AA battery on the old ones and a round watch style on the new ones.the voltage is listed on the battery,i think the AA one is 3.6 vdc.
    Feb 2008
    547
    Alex,
    Thanks for the info. My battery appears to be the round one and is not giving me any problems, I just felt it might be a good idea to change it as the machine is a 1996 and sat in storage for close to 8 years. I'm sorry but what do you mean by reloading the memory? The cpu is a 1400-4
    Steve
    Mar 2010
    memory
    memory as in programs,parameters,offsets and backlash and setto to reset atc.
    Apr 2005
    345
    On a 1400-4 board, there is a battery test button and indicator. (the lower of the two push buttons, top is a reset).
    So, I know I can meter the battery but, does a red light indicate "good" or "bad" on the battery test? hmmm
    http://www.scpconcepts.com
    Jan 2006
    64
    We had a 1990 4020 which was sold last week. It still had the original battery with no problems. We bought a replacement battery many years ago but never put it in. Wish the batterys in my cars would do so well lol.
    Sep 2012
    yes vmc15 has a decent battery backup and it can last for 3 days and how old the battery is it will only get discharged and it will work very fine and it will not be out of order
  1. Acramatic backup memory battery charging problem
    By cnc1000 in forum Cincinnati CNC
    Last Post: 03-17-2010, 07:00 PM
  2. MAZAK QT8 BATTERY BACKUP
    By nogginkj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2009, 11:30 AM
  3. Backup battery replacement
    By nogginkj in forum Fanuc
    Last Post: 10-08-2009, 05:27 AM
  4. Fanuc 10T Backup battery life support
    By zoeper in forum Fanuc
    Last Post: 12-19-2008, 04:21 PM
  5. MAHO DMU 80t battery backup location
    By suckerdave in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-13-2008, 01:09 PM
