586,106 active members*
3,027 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > why is machining referred as 2.5 axis?
Results 1 to 6 of 6
    Nov 2009
    82
    Why is machining on a 3 axis machine called 2.5 axis?
    Oct 2005
    672
    The 2.5D or 2-1/2 axis refers to the common parts where the Z axis plunges into the workpiece and then does not move while the X & Y axes do all the work. By comparision, 3D typically refers to surfacing/mold/die type operations where all three axes move simultaneously.
    Most VMCs will move all three axes simultaneously, but the CAD/CAM packages that generate the code differentiate between the types of operation.
    107
    Most machine controls do not have 3D capability. The X and Y axis interpolate together and the Z axis moves second. In a true 3D control, X Y and Z are fully interpolated. If you look at the readout in a 3D control, the three numbers are moving simultaneously.
    Jan 2004
    3154
    yep - full 3 axis takes massive amounts of calculations and 2.5d is really quite simple.
    www.integratedmechanical.ca
    May 2007
    781
    Quote Originally Posted by nwrepair1 View Post
    I would argue with that. Every mill I have run could do 3 axis moves, just that some were limited in how fast they could do it compared what is expected in a modern machine.
    I have seen a few CNC knee mills that would not do simultaneous 3 axis but I never run one.
    Oct 2006
    51
    my understanding of 2.5 axis machining is that you can only create an arc in 2 planes simultaneously. all the cnc machines i have used can cut x,y and z at the same time. but not arcs on 2 planes at the same time. plus even with a 4th axis, they only move 3 axis at one time.
  1. 5 axis machining.
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2008, 08:07 PM
  2. 6 Axis Machining
    By todd71 in forum Uncategorised MetalWorking Machines
    Last Post: 12-02-2006, 05:12 AM
  3. Are tachometers correctly referred to as encoders?
    By Smertrios in forum Stepper Motors / Drives
    Last Post: 10-06-2006, 12:13 AM
  4. 5-Axis Machining
    By 5AxisMachining in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2005, 04:03 PM
  5. 4th axis machining
    By senor J. in forum Visual Mill
    Last Post: 10-22-2004, 09:10 PM
