Fanuc 3Td power supply number a14b-0067-b001 is the one that seems to be the problem (the other two have been bench tested - the ice cube relays aren't getting power).
The machine suffered an over voltage condition while under power. I either need some help fixing it, or I need to replace it.
What other power supply's are available that would interchange with this one if it cannot be fixed?
