587,322 active members*
3,419 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 0.03mm backlash acceptable, yes/no?
Results 1 to 9 of 9
    Jan 2018
    1516
    0.03mm backlash seems to be as low as I can get at final testing. (0.0012")
    Machine has AC bearings & DFU nuts with extra shimming installed.
    Would you say it sounds about right?
    Mach3 Comp nudges the table if it's set above 0.125mm but I hate it's stop/start nature anyway.
    Will likely only use it on important circles and arcs.
    The rest of the time I'll use the stock to leave to add the 0.03mm on the parts or tweak the drawings if closer accuracy is required.
    It is only a benchtop
    May 2008
    1185
    Re: 0.03mm backlash acceptable, yes/no?
    If the mill is new then .0012" is fairly good.
    Backlash comes from all the components not just the ball nuts. On of the leading caused in a new mill is stick slip and way friction. After the ways break in the table will move easier and you might get under .001"
    I have had a few people over the years report large backlash with a system I knew was tight. I ask them to check how hard it is to move the axes by hand and almost every time the ways were set real tight or the gib strip was binding.
    I have seen .008" go to .0008"
    After the screws and ways break in you might be able to re shim the screws and get under .0005"
    Looks like a nice build, lots of screws.
    youtube videos of the G0704 under the name arizonavideo99
    Sep 2006
    509
    That level of backlash is probably more than fine, except if you are running a tiny end mill (i.e. 1/8" or smaller)... then backlash really becomes your enemy as it becomes significant relative to the chip load for the tool.
    May 2013
    149
    Rolled ballscrew are only good for .02mm positioning, if you want better you need to save up for ground screw which is alot more pricey.
    Wisdom results from foolishness!
    Mar 2014
    1131
    I have the same BF20 cnc'ed mill. Except my ballscrews are single. Backlash is about .05mm. Loosening way gibs didn't help.
    BTW, How did you managed to install double ball nuts on X and Y? It looked impossible when I convert mine.
    Best
    Jul 2018
    6469
    Hi Dazp - Wallace & Grommet would be chuffed with the cabinet work. Peter
    Jan 2018
    1516
    Quote Originally Posted by peteeng View Post
    It's functional. Lol.
    Wish I could weld.
    Jan 2018
    1516
    Quote Originally Posted by Azalin View Post
    Best
    I already had a dying sieg X2 conversion.
    Machined some of mine on there so the DFU would fit
    Jul 2018
    6469
    Hi Dazp - No welding sucks! Planes aren't welded and Mr Eiffel would be proud of you. Peter
  1. Acceptable accuracy
    By johnel1980 in forum DIY CNC Router Table Machines
    Last Post: 10-17-2017, 10:14 PM
  2. acceptable backlash
    By Deano7/11 in forum Linear and Rotary Motion
    Last Post: 10-07-2012, 02:33 PM
  3. Small Text - Acceptable Machine Backlash
    By snoman70 in forum Engraving Machines
    Last Post: 03-05-2008, 12:36 AM
  4. Maximum Acceptable Backlash and Climb Milling?
    By Oldmanandhistoy in forum MetalWork Discussion
    Last Post: 10-12-2007, 12:52 AM
  5. Is 0.005-0.010” of backlash with an Acme Screw acceptable?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2005, 03:50 PM
