588,653 active members*
6,306 visitors online*
Results 1 to 4 of 4
    Mar 2006
    489
    0-10V output control with Mach 3?
    I've searched but can't find much useful information on this subject.
    I have a breakout board from cnc4pc that has 0-10 output capability. Does anyone know how I would be able to use this from Mach3 for something like spindle speed control?
    I see where I can port M3 and M4 command to control relays on the board, but is there any built in way that I would be able to tie the 'S' word to send a signal to the breakout board which then outputs the equivalent 0-10V signal?
    Any help would be appreciated.
    Thanks,
    Paul
    Oct 2005
    80
    Spindle Control
    Paul,
    It sounds like you and I are both trying to do the same thing (control the speed of a spindle with Mach). What type of spindle motor and controller do you have. I have a 3-phase induction motor that I control with an Automation Direct inverter. I am trying to send the speed commands digitally using modbus.
    -Brian
    Mar 2003
    35538
    I don't know which board you have, but the manuals for both the C6 and C11 on their website explain how to set it up in Mach3.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2006
    489
    Thanks, I had an older version of the C11 manual that didn't explain how to use the analog output.
    Paul
