587,436 active members*
3,762 visitors online*
Thread: 0.3mm Brass
Results 1 to 4 of 4
    Jan 2007
    11
    Question 0.3mm Brass
    We manufacture models trains and we currently have our 0.3mm brass etched. The brass is either etched to 0.15mm or etched right through.
    Would I be able to do this using a 70w laser?
    How would I stop the laser from reflecting off the metal?
    if I can't do it using brass could you suggest a laserable material with similar thickness and bending characteristics as brass?
    Hillcraft,
    You will not be able to do this with 70 Watts at the wavelength of the CO2 laser.
    Brass can be 'marked' using 'thermark' or similar product but not etched. I think the brass is just too good a reflector.
    Tweakie.
    CNC is only limited by our imagination.
    Jan 2007
    11
    0.3mm material
    What other material could I use that is 0.3mm thick, can be engraved to 0.15mm and will not break if folded along an engraved line?
    Apr 2006
    251
    No metals would fit those requirements. You get a more precise result with etching anyway.
  1. F&S for 353 brass
    By ecotectoo in forum MetalWork Discussion
    Last Post: 06-10-2008, 07:14 PM
  2. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
  3. Brass...why?
    By creative_mind in forum MetalWork Discussion
    Last Post: 05-25-2004, 06:27 AM
  4. How can I cut Brass?
    By cbcnc in forum MetalWork Discussion
    Last Post: 01-14-2004, 02:54 AM
  5. Where to buy Brass?
    By NeoMoses in forum MetalWork Discussion
    Last Post: 10-06-2003, 02:35 AM
