588,138 active members*
6,811 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 0.75 and 1.00 inch shell mill arbors
Results 1 to 5 of 5
    Nov 2012
    220
    This has been nagging me, so I thought I would post it up and see if anyone wants to run with it.
    Why is no one making and selling 0.75 inch and 1.00 inch shell mill arbors from the Tormach tool blank they sell? I would buy them.
    Apr 2013
    1788
    Re: 0.75 and 1.00 inch shell mill arbors
    Why not buy a straight shank arbor (3/4x3/4" Shell Mill Arbor - Tool Holders - Toolholding & Workholding - Products and 3/4x1" Shell Mill Arbor - Tool Holders - Toolholding & Workholding - Products) and add a TTS ring (Tormach 32432)? You can probably find cheaper arbors on eBay but the Shars website was convenient.
    Nov 2012
    220
    Sometimes it nice just buying something off of the shelf and having it show up done.
    Nov 2010
    291
    I bought one and cut and turned it. It was a job on my 13x40 using carbide. After doing it I would just buy one that fit. Like most things here it depends if you are making money with this or not. It would have been way cheaper and easier to but the best fitting one but I had time. The arbor should be about the same price for most sizes I think and see no reason why there isn't one already.
    Mar 2009
    1863
    Quote Originally Posted by gcofieldd View Post
    You can get a 2 inch Shear Hog with a 3/4 inch shank. I made some collars with .003 press fit. I heat the collars and slide them to where I want them and cool it down. With .003 press fit there's no way it's going move.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
  1. Shell Mill Cutter v/s Shear Hog Insert Mill
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 12-07-2015, 08:03 PM
  2. Shell mill arbors for HSL 63F
    By adfergusson in forum CNC Tooling
    Last Post: 03-07-2014, 02:52 PM
  3. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  4. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  5. Using a shell mill
    By mrk in forum MetalWork Discussion
    Last Post: 08-11-2007, 02:59 PM
