587,760 active members*
2,668 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 0m-a G90 absolute G91 incremental no difference?
Results 1 to 6 of 6
Hybrid View
    Sep 2012
    182
    I have searched on this issue but it seems G90 (abs) and G91(inc) are so self explanatory there isn't much info on them.
    either mode has the same effect for me.
    I zero the machine manually.
    then move the table to about the middle.
    g90 G00 X200.00 y-150.00
    all the co-ordinate systems (absolute, relative and machine) move to x200.00 y-150.00
    then if I enter G90 x20.00 y-20.00
    the table moves to X220.00 and y-170.00
    I was under the impression that in absolute mode x20.00 y-20.00 is 20mm both x and y from the absolute zero.
    if I use G91 the machine behaves the same. incremental positioning from the last location.
    what am I doing wrong?
    Feb 2007
    664
    try just x20.00 y-20.00 or G00 x20.00 y-20.00 or G01 x20.00 y-20.00 F10.10
    Sep 2012
    182
    ^ tested those.
    moves incremental from the x200 y-150.
    G90 is modal and is on the screen. the machine starts up with g90 as the default.
    Aug 2007
    793
    if it occures in MDI mode you should set ABS to 1 on 1-st page of settings
    Sep 2012
    182
    thanks guhl! that was it. simple fix.
    Sep 2012
    182
    this came back to haunt me today.
    I thought I had both G90 and G91 working by setting ABS=1. I thought I tested it after the change and had both G90 and G91 working.
    however to day when performing a G28 z0.0, after first changing to G91, the machine it plunged down to the z0 before going to the reference point.
    so I tested G90 x30. and it went to x30. then G91 x-20. expecting X10. and I got an over travel as it went to ABS x-20.
    it is now behaving like it only has ABS.
    anything I can try?
  1. From incremental to Absolute,
    By CharlieM in forum BobCad-Cam
    Last Post: 12-03-2010, 02:33 PM
  2. Incremental Vs Absolute mode
    By chilly2k in forum Mach Wizards, Macros, & Addons
    Last Post: 03-06-2009, 11:54 PM
  3. Subroutine and Absolute/Incremental
    By VWbmx in forum G-Code Programing
    Last Post: 02-22-2009, 08:09 PM
  4. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
