587,997 active members*
1,689 visitors online*
Results 1 to 4 of 4
    Dec 2005
    7
    0ma tool changer problem
    I have read some of the other posts regarding this type pf problem and I am not sure if my problem is similar or not. I had an event the other day which corrupted my memory. I was able to clear things them re-install my paramators. I lost a program o9500 which I had previously thought was a return to home program but as I read may have been the tool changer macro. Still kind of confused about how that works. That was my only 9000 series program which I had prior tho the reset. When I call for a tool change the machine pulls the tool in the spindle then proceeds to rotate the tools in the carosel non stop. It apears that the control is unable to recognise that the changer is rotating and does not index the change in position. If you manually turn the tool changer motor the magnetic sensor throws a limit switch error but will not recognise that the carosel has moved and the controldisplay always says tool one. The only way to stop the rotation is to turn the control off. I am kinda new at all this and have been teaching myself so I appreciate any wisdom. Thanks Scott
    Feb 2007
    314
    i don't think tool change macro is the problem. When M6 call a macro wich is not in memory, control alarm out and it is not your case. Maybe timer, counter and keep relay are not set correctly.
    Samu's right.
    It wouldn't have part done a TC if that O9000 program was a tool change macro
    Counters
    Keeprelays
    all located on the DIAGNOSTICS page
    this is where i'd check first
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Dec 2005
    7
    where would I find info about the timer and keep relay I do not have a ladder from the manufacture.
  1. partner 1 tool changer problem
    By blowncoupe in forum Milltronics
    Last Post: 06-29-2015, 06:21 PM
  2. tool changer problem
    By kling8 in forum Mori Seiki Mills
    Last Post: 02-25-2010, 02:54 PM
  3. Mitsubishi 520 Tool Changer problem
    By acrodave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-24-2008, 02:58 PM
  4. random tool-changer problem
    By hicarbon07 in forum Community Club House
    Last Post: 08-28-2008, 12:00 AM
  5. tool changer problem
    By concordezz in forum Haas Mills
    Last Post: 08-20-2008, 09:04 PM
