586,069 active members*
3,820 visitors online*
Results 1 to 4 of 4
    Oct 2011
    25
    1/2" NPT taper thread using G76
    Hi all,
    I need to screwcut a 1/2 NPT thread, 18mm in length using a fanuc oi control (2 line G76)
    I've been searching here & elsewhere & have come up with a prog.
    Would be grateful if you could have a look & see what you think:
    (there is a relief at the front of the part, so I can start straight from Z0)
    N3 T0303 (1/2 NPT - 14)
    G97 S350 M3
    G00 G99 X100. Z0.
    G00 G40 G99 X22. M8
    G76 P030060 Q40 R0.03
    G76 X18.432 Z-18. P1500 R-0.562 Q200 F1.814 (Where: X = Pipe OD -(2 X HEIGHT) and R = (18/16) /2 )
    G28 U0 M9
    G28 W0
    M01
    Many thanks in advance for any advice
    David
    Oct 2011
    25
    Just for reference, I tried it, & it worked fine,
    Thanks to all who viewed
    D
    dear sir
    would you pls let me know how to calclulate the tapper dimentions
    Jan 2010
    29
    Non Folker. Dude you really helped me to make that G-code for a 1/2NPT part. Dude I made some Drawings (3/8 NPT, 1/2 NPT) I can happy share with all of you
  1. Replies: 2
    Last Post: 01-25-2013, 04:38 PM
  2. Special ID thread. sp-400 "M" type thread 8TPI
    By Captain Crunch in forum MetalWork Discussion
    Last Post: 04-05-2012, 09:39 AM
  3. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  4. taper thread
    By gcrandall in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 04:13 PM
