603,546 active members*
2,966 visitors online*
Results 1 to 6 of 6
    Sep 2005
    39
    1/4 NPT External thread program
    Can someone help me with programming 1/4 npt external using G76 (fanuc O-T). I do not know what values to put in for the thread dimensions. Thanks!
    Feb 2006
    992
    .54 dia start point with 1.75deg per side. Is it help.
    The best way to learn is trial error.
    Mar 2007
    6
    I'm threading 1/4 npt threads on a fanuc ot controled cnc lathe. Can anyone give me some help on the second line of info using G76?
    Jul 2005
    12177
    Lead is 18 threads per inch, taper is 0.0625" per inch diameter measure, finish diameter is around 0.56", length is around 1/2".
    May 2007
    1003
    Thread ending point figured at center of 16ER 18 NPT insert and L4 dimension from Machinery's Handbook.
    Finish turn .016R insert
    X.3768Z0
    G3X.4065Z-.0062R.021
    G1X.5249Z-.0653
    X.54Z-.3077
    Z-?
    Finish turn .031R insert
    X.3468Z0
    G3X.3977Z-.0105R.036
    G1X.5245Z-.0739
    X.54Z-.3224
    Z-?
    Thread 1/4-18 NPT external
    X.58Z.3
    G76P000155Q30
    G76X.467Z-.634P444Q150R-.0291F.05556
    Changing starting point or ending point will require R to be modified. R=tan(1+47/60)*(start point + end point) unless both points are the same sign, in which case you would subtract them.
    Single block G76
    X.58Z.3
    G76X.467Z-.634I-.0291K.0444D150F.0556A50.
    Did one of these work okay for you?
    May 2007
    1003
    Apparently my examples didn't work. What did you finally wind up with?
  1. Mach3 and external PCI parallel card?
    By Cooper in forum Mach Mill
    Last Post: 01-20-2013, 01:30 PM
  2. External E-stop Requested ??? Wtf!
    By diarmaid in forum Mach Mill
    Last Post: 12-10-2006, 09:51 PM
  3. 2-1/2 - 8 NPT Thread Mill Program
    By wesleybridgepor in forum MetalWork Discussion
    Last Post: 11-30-2006, 11:56 AM
  4. External cmos battery?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2006, 01:51 AM
  5. external start stop
    By drk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2005, 05:21 PM
