588,528 active members*
6,122 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > 1 inch - .025 = degrees How to solve these types of problems?
Results 1 to 7 of 7
    Oct 2012
    In CNC programming I need a formula to solve these problems to calculate ramp angle. I tried (rise/run)tan-1 and I think that is giving me an interior angle as when converting the problem to a triangle.
    May 2004
    4519
    Study your trig functions.
    Nov 2008
    24
    Oct 2012
    Thanks.. I think this is just what I needed.
    Oct 2012
    I looked at it. The site is saying for me to solve the way I have been doing it. rise/run tan-1(rise/run). My answers are way to small. I keep getting 1-2 degrees.
    May 2004
    4519
    Quote Originally Posted by lost View Post
    You better be getting the same answer every time. And it better be 1.43 degrees.
    Nov 2008
    24
    I never trust myself fully so I usually double check any angle or arc dimensions I'm not sure about with a 2d cad program.
    -gk
  1. Replies: 4
    Last Post: 09-11-2012, 10:30 PM
  2. Milling 1/16 inch metal problems what speed?
    By Micro Milling in forum MetalWork Discussion
    Last Post: 12-16-2009, 06:49 PM
  3. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  4. Problems bending ½ inch pipe
    By travis_towle in forum Bending, Forging, Extrusion...
    Last Post: 03-08-2007, 01:06 PM
