588,080 active members*
4,833 visitors online*
Results 1 to 7 of 7
    Jan 2006
    37
    10M weird Z movement
    I got a problem with my Z axis on my mori mill with fanuc 10M controller. Ocassionally when i program a move in Z direction with G0 in MDI, then the Z axis starts to move at full speed (does not care about rapid feed override switch, really very fast) in either direction until an EXCESS MOVE alarm is raised. The alarm is raised after some travel, once it was few cm's, next time cca 25cm. This seems to be very dangerous, until now seems i got lucky enough the spindle moved upwards.
    There is one more thing worth to mention - last two times it happened after i ran a long program via rs232 (ran ok, then i wanted to move the spindle to a certain position), the last command was G28G0Z0, which i used to interrupt in half way with the reset button.
    Any suggestions?
    thanks in advance
    Dec 2003
    24220
    It sounds like an axis run-away condition, are these DC motors with tachs?
    Al.
    Albert E.
    Jun 2007
    3735
    Or is it in relative mode, and z5 gives an instant incremental Z move upwards?
    Feb 2009
    6028
    You must use a g91g28z0, otherwise the z will dive to part zero first. Also make sure your not in inches per revolution mode.
    Jan 2006
    37
    The motors are DC's with encoders.
    Also it did not matter whether the machine was in G91 or G90...i'm pretty sure this is not the intended behavior. If it was correct, then it would move with the standard rapid speed (set to 3000 mm/min).
    For me it seems to be a bug in the controller or HW error - also it happens only on the Z axis.
    Feb 2009
    6028
    Wow, almost never saw yellow cap motors on a mori with a 10! You have a tach failing in the motor.
    Dec 2003
    24220
    Soon after the introduction of the 10 was about the time Fanuc transitioned over to Red Cap AC servo's.
    At this time there were some of the DC servo's fitted with resolvers in place of encoders and tachs.
    These were driven off of a small gear on the rear shaft.
    Al.
    Albert E.
  1. Erratic Z movement AND NO X Y MOVEMENT
    By 05miata in forum Mach Mill
    Last Post: 06-04-2012, 03:10 PM
  2. PIC/297/298 WEIRD MOVEMENT, It will jus take a minuit. THANKX.
    By ellasaro in forum Open Source Controller Boards
    Last Post: 02-16-2012, 03:18 PM
  3. PIC/297/298 STEP LOSS & WEIRD MOVEMENT
    By ellasaro in forum Hobby Discussion
    Last Post: 02-16-2012, 02:36 PM
  4. weird movement
    By corrie in forum Machines running Mach Software
    Last Post: 11-27-2008, 05:03 AM
  5. Weird?
    By Klox in forum Uncategorised CAM Discussion
    Last Post: 11-19-2003, 05:04 AM
