At 8.5amps 1.5hp on single phase I would expect that to be 220, on 110 the current would be higher. You can provide a 220 plug by running a 14gx2 with ground to your panel and put in a double 220v breaker, the 15 amp sockets you can buy have the pins horizontal instead of vertical like the 120v type.
Is the capacitor supplied with the motor, or is it on the outside somewhere?
Al.
Albert E.
