Hello friends
I plan to convert a BF30-type benchtop mill to cnc (840x210 mm table). My original goal was to achieve at least 10 m/min rapids, and after some thought I realised I probably wasn't going to reach those speeds with these ways. Rather than spend half a quadrillion years scraping the ways to perfection only to come to the conclusion that 10m/min still isn't possible, I've decided to go the linear guide route. I want to fit Hiwin RG-series rails; and I've got a design modeled for 15 mm rails (https://i.imgur.com/lq9psPH.png).
The z-axis column would probably to be shaved down some more to fit the bigger blocks, so --ridigity from that, and ++ridigity from the bigger rails; cancels out, not worth?
The y-axis would require the saddle to become thinner so I can even get the bolt holes anywhere near a flat surface on the saddle (https://i.imgur.com/ZLC9ZPy.png), and I kind of want to avoid having to make a completely new saddle (because I don't know where to get the material from for a reasonable price)
The x-axis is the most likely candidate where 20 mm rails can be installed since there's plenty of room on the saddle and table for that.
My question is, before I go and redo anything, is it worth the effort? Will I even notice the difference in practice? Do the x-axis, leave y and z as is?
Idk, just want to know what you guys think
Cheers
