587,972 active members*
4,461 visitors online*
Results 1 to 12 of 12
    Sep 2011
    78
    18iT cancelling G41/G42
    I have the following question.
    When stopping an automated operation with nose radius compensation the compensation is not cancceld by the reset button.
    I have to G40 by MDI to cancell the nose radius compensation.
    Is there a parameter setting that has to be changed so that G41/G42 is cancceld by reset , and if so is there also one for automated cancelling the radius compensation when the program end and rewinds with M30.
    just wondering.
    Mar 2003
    2932
    Why not add the G40 to the program?
    Sep 2011
    78
    I do. but when I interrupt the program before the G41 is cancelled and decide not to continue but restart the programm ( for example because of a material/ workpiece defect) by using Edit-reset the radius compensation is not cancelled but remains active.
    May 2004
    4519
    Also avoiding resetting during the G41/G42 is helpful. You really should not have to reset very often if you are getting your programming and machining methods right the first time.
    I usually put G40 in the start code for each tool process. Same with G80. That way when I do have to restart, I know everything is in the proper condition.
    Feb 2008
    586
    Quote Originally Posted by txcncman View Post
    +1 on this. A start block for any single operation should have what you need for recovery to a prior setting, like a G40, G80, even inch versus metric if you use it, and G90 vs. G91 if applicable.
    Beege
    Jun 2005
    142
    ditto txcncman.
    best practice would be to start each tool in a state that YOU have set.
    Sep 2011
    78
    I agree that the best way is to start with G40 when no radius comp. is needed but thats not realy a answer to the question if it's possible to cancel G41/42 with the restet button regardless of what would be the smartest thing to do
    May 2004
    4519
    I do not have a manual for an 18iT control. I suggest you consult the manual to find your answer or contact your nearest service center.
    Mar 2003
    2932
    Quote Originally Posted by duivenhok View Post
    I haven't tried this myself...
    3402 bit 6 (CLR)=1
    3406 bit 7 (C07)=0
    See attachments.
    Let us know, please.
    Dave
    Attached Thumbnails Attached Thumbnails F18i Prm 3402 bit 6.jpg   F18i Prm 3406 Explanation.jpg   F18i Prm 3406.jpg
    Sep 2010
    1230
    Quote Originally Posted by dcoupar View Post
    3402 bit 6 (CLR)=1
    3406 bit 7 (C07)=0
    See attachments.
    Dave
    Hi Dave,
    I tested this on an 0i control today. Prepared a program to use cutter rad comp and no G40 prior to the cutter rad comp being initiated. On this particular machine 3402.6 and 3406.7 were already set 1 and 0 respectively and Reset could be launched during cutter rad comp without any consequence when running the cutter rad comp part of the program again.
    Setting these parameter bits mirror to that shown above made no difference whatsoever, the machine still ran the program again without error after Resetting when cutter rad comp was active.
    Regards,
    Bill
    Aug 2011
    2517
    the manual has no specific parameter setting to cancel G41/G42 with reset.
    parameter 5003 might help.
    bit 6 and bit 7 when set to 1 will clear wear and geometry offsets when reset is pressed.
    bit 2 when set to 1 *will* cancel tool nose radius compensation but only when the machine is zero-returned.
    Feb 2006
    1792
    Not sure, but
    3402#6(CLR)=1 and 3409#7(CFH)=0 might work.
  1. Cancelling tool select
    By CNC-Hammer in forum Okuma
    Last Post: 04-10-2014, 08:08 AM
  2. FANUC 18iT, muting the lamp
    By MRPM in forum Fanuc
    Last Post: 04-07-2011, 09:52 PM
  3. FANUC 18iT, G41/G42 and G71/G72/G73
    Last Post: 03-26-2011, 08:32 PM
  4. Noise cancelling headphones?
    By boblon in forum Wood Lathes / Mills
    Last Post: 12-07-2010, 12:53 PM
  5. Screw cutting on 18iT
    By clarke200 in forum Fanuc
    Last Post: 06-22-2007, 02:18 AM
