A used Fadal 4020 was recently purchased and was moved into the shop - with the spindle coolant tank missing.
If anyone could post a picture of a tank showing the size, location and hookups, it would be greatly appreciated.
Thanks.
-jon
Thanks.
-jon
I use a cut down 5 gallon bucket for mine as my tank was missing as well.
There should be a hose from the chiller (return line) and a hose from the pump (suction) to put into your pail of 50:50 mix Dowfrost.
This is all under the assumption that an 87 is the same setup as my 94 (I don't know).
www.integratedmechanical.ca
