603,897 active members*
3,515 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > 1996 HAAS VF3 Spindle Not Orienting, Load Spikes
    I have a 1996 HAAS VF3, 7500 RPMs.
    It will not orient its spindle correctly, doesnt repeat position, sometimes it spins and changes directions for a while, have replaced the encoder, and vector drive, and the behavior still remains. Have tested the spindle motor separately both with an external drive, and connected directly to power source and it seems to work ok.
    When its connected to the machine and I ask it to execute any m03 command, spindle load either fluctuates from 150% to 180%, or just plain spikes to 200%.
    Another abnormal behavior is, when I give it a m03 s1900, encoder reads 270-300 rpm, fluctuating, visually, it is spinning at about that speed.
    If i give it m03 s4000, encoder still reads 270-300rpm, and is visually at same speed as that of the m03s1900 command. So, apparently, no matter the speed you ask, it wont accelerate past that speed, same behavior in low gear, except rpms read at about 80-90 rpms.
    These are the parameters it is currently running, as found
    Parameter 79 Spindle Steps/Rev 4000
    Parameter 120 Spindle Acc/Decel 100
    Parameter 182 C Acceleration 2,000,000
    Parameter 186 C Deceleration 50,000
    Parameter 187 High Gear Steps/Rev 5000
    Parameter 188 C Orient Gain 1000
    Parameter 189 C Base Freq 70
    Parameter 193 Spindle Orient Margin 50
    Parameter 194 Spindle Stop Speed 5
    Parameter 174 B Spindle Temp. Coef 0
    Parameter 205 A Spindle temp Coef 0
    Parameter 208 Spindle Fan Off Delay 60
    Parameter 238 TSC Max Spindle RPM 7500
    Parameter 239 Spindle Encoder Steps/Rev 8000
    Parameter 257 Spindle Orient Offset 484
    Have also tried with a different MOCON, tested the 640C cable that runs from vector drive to MOCON, and the 33 1000A Spindle encoder cable
    Am about to run some more tests with a tachometer, will keep updating posts.
    Dec 2023
    3
    Re: 1996 HAAS VF3 Spindle Not Orienting, Load Spikes
    Sounds like an interesting problem. Have you found where te problem lies?
  1. How to correct reversal spikes on haas?
    By DaOne in forum Haas Mills
    Last Post: 05-02-2020, 08:06 PM
  2. Changing Haas vf3 spindle bearings
    By fastguys in forum Haas Mills
    Last Post: 11-11-2019, 03:53 AM
  3. Haas 2005 VF3 Spindle RPM Mismatch
    By Manjeet in forum Haas Mills
    Last Post: 04-29-2019, 05:27 AM
  4. Hass vf3 manufactured 1996 . z axis drive fault
    By dunchadh in forum Haas Mills
    Last Post: 04-08-2019, 06:24 PM
  5. Haas VF3 1996 not finding Z-ref.
    By Nordic in forum Haas Mills
    Last Post: 10-29-2010, 06:16 PM
