588,619 active members*
5,199 visitors online*
    Sep 2008
    1997 Bridgeport VMC800 DX32
    Hello,
    I was wondering if anyone knows if a memory card reader could be installed to this controller. I would like to find a more simple way to load and store back up programs. All my programs now are installed by the floppy drive.
    Thanks,
    pbrtoolmaker
    Dec 2005
    3319
    The answer to your question may be found in reply number 4 in the following thread.
    http://www.cnczone.com/forums/showth...161#post518161
    The installation of Win 98 solves some problems and creates others. First, the HDD for the DX32 system has to be only 504mb in size, This was the BPT standard in the day that the DX32 was created.
    The way I'd do it is to install a larger drive, Format it so C is 504mb and then partition the rest out as you see fit. Load DOS/BMDC O/S onto C and Win 98 on D.
    YOU can then store as you see fit on the other drives you format/partition. If you do this, you'd better learn how to toggle into and out of DOS and/or your machine's BMDC program. This may not be viable with a CIB but can be done with a PC based system.
  1. DX32 questions (Bridgeport Torq Cut 22, DX-32, DX 32)
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2016, 07:54 AM
  2. 1997 Bridgeport VMC 800 for sale
    By jrjoet in forum Bridgeport / Hardinge Mills
    Last Post: 07-11-2008, 08:42 PM
  3. Spindle runaway when orienting, Bridgeport VMC800 digital
    By rodgull in forum Bridgeport / Hardinge Mills
    Last Post: 08-16-2007, 04:14 PM
  4. need Bridgeport discovery DX32 programming help
    By dfelice in forum Bridgeport / Hardinge Mills
    Last Post: 07-17-2007, 03:24 PM
