603,942 active members*
4,198 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > 1st Time building a custom machine
    Aug 2024
    Hi all, I'm attempting to design a custom thermoforming machine and I'm considering using a CNC controller to run it. I've worked with HAAS machines for years but have no experience building my own controllers in a DIY capacity. What I really need is a controller/driver set up that can accommodate (2) axes and (4) pneumatic solenoids, with the ability to set up a work offset being a critically specific need. What I've got is a pretty good idea but no knowledge to execute. Any help recommending systems (someone plz just hold my hand -whimpers-) would be appreciated, thx!
    Nov 2013
    5412
    Re: 1st Time building a custom machine
    the majority of CNC hobby control solutions will handily do as you require.
    I will restrict myself to the four main hobby CNC solutions discussed here, but there more.
    I use Mach4 and have done for many years. Mach3 was very VERY popular and still works and has a loyal fanbase despite all development on it having ceased nine years ago. Either would work for you,
    but Mach4 would be preferred for a new build. Mach4 all but requires a separate motion control board, and I use an Ethernet SmoothStepper, but there are others by other manufacturers which also work well
    and are cost effective.
    UCCNC is a software solution made by CNCDrive, and when coupled with one of their motion control boards, the UC300 for example, makes for a good and pretty complete CNC solution.
    LinuxCNC is an open source CNC software solution that runs on a PC loaded with a realtime Linux distro. It is very capable and has a wide user base. In fact the current Haas control is a variant or offshoot of
    LinuxCNC....so pretty much anything that Haas can do so will LinuxCNC.
    A more commercial and almost turn key solution is Centroid Acorn. It is perhaps a little less flexible than the others I've mentioned, but is well sorted and therefore favours those without CNC electronics experience.
    Any of these solutions would do as you require very easily, and is a fair place to start your research.
    Craig
    Apr 2007
    34
    I would suggest FluidNC or one of the other GRBL variants. They are open source and don't require expensive electronics. They send standard G code over USB and can be configured to meet your needs. Grbl is used on many 3D printers and Laser cutter / engravers. Linux CNC too fickle and learning cure is long to get it right.
  1. CNC Machining, Custom Automation, Machine Building and More
    By SalibaIndustriesInc in forum Manufacture Company Listing
    Last Post: 01-31-2022, 05:13 PM
  2. building a custom virtual machine for machine simulation
    By Lozzy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-20-2018, 10:22 AM
  3. building my 1st milling machine - first steps in action
    By M-Malek in forum Mechanical Calculations/Engineering Design
    Last Post: 02-11-2017, 09:19 AM
  4. Looking for some help building 1st cnc
    By NekoMew in forum USA Club House
    Last Post: 01-17-2017, 06:13 AM
  5. Building 1st router.
    By skipper_52 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2008, 12:44 AM
