Hello all,
here comes the probably dumbest question in this section ever ...
Anyhow, I am not an electrician and to make it even more complicated, I am from a 230V country. For heavy machinery we use three phase alternating current with 380V and there is only one plug design.
Recently I bought a 2.2 kW china spindle with a VFD 220V which is still in route. Meanwhile I had asked an electrician to install 220V power outlet to run the spindle. When he was done I found out that he had installed the line but no receptacle and he told me, that he can't install a receptacle as long as he doesn't know what amperage the machine would need and walked away.
OK this was the moment when I realized that there seem to be a plethora of plugs and receptacles for 220V in this country
![Confused](images/smilies/confused.png)
. Looking somewhat closer I found out that they basically differentiate from each other, except for the design, by the allowed amperage. Unfortunately that doesn't make it much easier to choose the right one because l have no idea what amperage I have to choose, nor if a special design which would be preferred.
I would certainly appreciate if somebody could help with some information in this aspect, I am pretty sure that for most of you this is a no brainer.
Thank you
Chris
