587,997 active members*
1,666 visitors online*
Thread: 2.5 vs 3d
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2009
    24
    2.5 vs 3d
    I hope this is the correct area for this. I am still struggling with the difference between 2.5 and 3d. There is quite a difference in price between the two softwares. I would like to see some pictures of complex 2.5d projects if you have any.
    Most specifically I want to know about Dolphin Partmaster Pro.
    Can hemisphere/dome or convex/dish machining be done with it?
    Do all three axes move simultaneously?
    Please excuse my ignorance, I have no experience with CNC at all, but want to.
    Please don't forget pics!
    Sep 2007
    359
    csaw
    I know how you feel.
    But 2.5D is a shape with a constant Z depth setting for the profile the only exception is when you may have a ramping motion set for the PLUNGE and then it runs X & Y at a constant Z depth
    3D is any shape where all three axis may be moving at once
    Then there will be a step up in price again for 4th axis and even more for 5th axis
    Phil
    Jan 2006
    4396
    I can't help you with Dolphin but can make references to 2.5D and 3D.
    CAD and CAM are different in the aspects of 2.5D and 3D.
    This is a part created in a 2D CAD environment using various plains, 2D Geometry, with Solids.
    This part will need a 3 Axis Mill to machine it.
    Attached Files Attached Files
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jan 2006
    4396
    This one is 2.5D and has no need for 3 Axis Machining
    Toby D.
    Schwarzwald
    Mar 2003
    35538
    Quote Originally Posted by tobyaxis View Post
    That's not helping at all. A 2D CAD program can't do that part. It's created in a 3D CAD modeler. Help the guy, don't confuse him.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2006
    4396
    The second post is a 2.5D part. I separated the posts to avoid confusion.
    You have a point with the software being used though. I might be able to find a BobCAD file that is 2D for a better example.
    Toby D.
    Schwarzwald
    Apr 2005
    3634
    Ok,
    2.5D can be done on a 3 or 4-axis machine (X,Y,Z,A)
    3D would be 5-axis or greater (A,C,X,Y,Z), rotary axis both depend on your machine (A,C-axis names).
    It's really all about how you setup the part, you could cut a 3D part with 2.5D software, but when you go to index the part (by hand) you better have a good fixture on your machine to align everything.
    I think your ?'s would be better answered If you post a photo of the part you want to cut.
    Free DXF - vectorink.com
    Apr 2005
    3634
    How would you cut that part in your .pdf file with less than 3-axis?
    Apr 2005
    3634
    Vectric has a program called Cut3D, that you can use on a 3-axis machine to get very close to 3D.
    Still it's not full 3D (undercuts, etc...), the program only supports 3-axis (X,Y,Z), I understand why they did this, much larger market of machines that are only 3-axis.
    It's still great software.
    Jan 2006
    4396
    Here is a reference from the machinery's handbook on 2.5D vs 3D.
    On the left is 3D and on the right 2.5D drawn in an isometric projection.
    Toby D.
    Schwarzwald
    Jan 2006
    4396
    Quote Originally Posted by Switcher View Post
    The Reference 2.5D Machining means that you have X,Y, & Z but the Z Axis is only for Depth. A friend of mine has a Proto-Track VMC where the Z-Axis can only be used for depth, hence he can't not do anything requiring Full 3 Axis.
    That shoulder harness was machined using a 2.5D method. There are no Z Feeds in the program, only Z depths
    The differences of 2.5D and 3D can get confusing when asking about both CAD and CAM.
    In CAD you can create a Square Box on a flat 2D plane. Place a Depth Dimension on that same box and machine it. Now you have a 3D Box or Cube.
    No pun intended but your definition wasn't exactly great either, because it is difficult to explain to a person in words. Now if we were all in the same room next to a VMC we could do that in about 2 seconds and show great examples.
    Like I said, it can be difficult to explain.
    Toby D.
    Schwarzwald
    Jul 2006
    66
    Full 3D Yes ProtoTrak
    Toby, A friend of mine has a Prototrak that does full 3 X work, he purchased the DNC key.
    "I'll keep my gun, my ammo, my money, my freedom and you can keep the "CHANGE" !
    May 2005
    2502
    I think the first definition is the clearest:
    "But 2.5D is a shape with a constant Z depth setting for the profile the only exception is when you may have a ramping motion set for the PLUNGE and then it runs X & Y at a constant Z depth
    3D is any shape where all three axis may be moving at once."
    Another way to think about it is (roughly) what sort of tool paths can the program generate?
    A 2.5D can drill holes, follow a profile at constant depth, or make a pocket at constant depth. That's about it. They will have some variations on that, but the emphasis is on constant depth.
    A 3D will be capable of smoothly moving the cutter up and down to create smoothly flowing shapes. Most newcomers dream of 3D, but they get to building real parts and often realize an awful lot can be done with 2.5D.
    The seatbelt clip Toby shows, for example, looks smoothly flowing, but with corner rounding endmills and such, is a pretty easy 2.5D part.
    Now 4-axis says we want to rotate on one axis as well, usually the X. And there are 2 styles there too:
    1. I want to rotate for indexing only. I will stop and lock the rotation before cutting.
    2. I want to rotate while cutting.
    Case #1 is largely (but not exclusively) handy so you can get at more sides of your part without having to remove it from the machine and reposition it.
    Case #2 is less often important, but has cool applications. For example, engraving a shape that smoothly wraps around a cylinder.
    5-axis rotates 2 of the linear axes, such as x and y. It's all about being able to reach into crazy places without refixturing. Porting a cylinder head, for example.
    Each step up that list seems to multiply the cost of the software by 2x, so we seldom see 5-axis among amateurs. Though there are some wonderful exceptions:
    http://www.cnc-toolkit.com/
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    May 2005
    1662
    BobWarfield's explanation for the win (imho)
    And then I'll play devils advocate to be a jerk
    Spiral cutting a counter bore would be an example of simultaneous 3 axis motion resulting in a 2+1/2 D profile.
    A hemisphere is 3d but the general shape could be cut with a 2+1/2D strategy. I've never used a control that will do cutter compensation in the x-z plane however so most people would resort to 3D CAM.
    Anyone who says "It only goes together one way" has no imagination.
    May 2005
    1662
    A OT question.
    Years ago I worked with a conversational Mazak (Mazatrol) control that could do fairly complex 2+1/2D work. Have the newer conversational controls moved into 3D ?
    May 2005
    2502
    Quote Originally Posted by cyclestart View Post
    LOL!
    So, I'll pose this question (at the risk of being a jerk back, LOL), does the helical interpretation g-code have to "know" it is a 3D operation in the same way that most 3D g-code does?
    Likewise, a ramp would be similar.
    Of course the answer is the g-code makes it look like just another 2 1/2 D op.
    I haven't seen any conversational 3D but would be fascinated to hear of some.
    Cheers,
    BW
    PS For something like the hemispheres, or other very regular shapes, it isn't hard to hand program the g-code. I like to use Excel to do odd things like that (even though I have a 3D CAM). Calculate the coordinates and then use string formulas to create the g-code. Cut and paste and you are there.
  17. #17
    Apr 2005
    3634
    I ran this conversational software for about 8 years on a Schutte WU305 5-axis tool grinder, Windows NT at the Siemens Control.
    It's wild to watch the g-code file on the monitor, while the machine is running the full 5-axis simultaneously (example: the rake on a ball end-mill), the text file scrolls so fast it's just a blur
  18. #18
    Aug 2008
    199
    hi everyone
    another explanation on this website
    http://www.shopbottools.com/3-d_work_v2.htm
    for CNC woodcarving - 3d puzzle - furnitures
    http://pagesperso-orange.fr/fabrun/
  19. #19
    Mar 2003
    35538
    Here's some 2.5D mouldings I cut the other day. All just straight X axis moves. You can do curved parts like this too.
    http://www.cnczone.com/forums/showpo...&postcount=181
    I don't think anyone mentioned it yet, but using 2D toolpaths for parts like this usually result in much smaller file sizes and much faster run times.
    Basically, 2D or 2.5D is cutting in X and Y only, with Z movements between cuts. 3D is X, Y, and Z all moving together, but sometimes just X and Z or Y and Z, depending on the CAM software and the paths it generates.
    And there are inexpensive 3D packages, like MeshCAM and Cut3D, but they may not be the right option for some applications.
    Gerry
  20. #20
    May 2005
    1662
    Quote Originally Posted by BobWarfield View Post
    LOL!
    I was just up to some mischief, your explanation was excellent. The spiral routines in simple CAM go from here-to-there following a canned strategy as you explained. Good enough for a vertical wall. Blending shapes in 3 dimensions and understanding tool shapes is more complex.
    A conversational control (question and answer) could be thought of as a type of CAM without the usual CAD method. The questions for 3D would get complex pretty fast
    Maybe that could be thought of as a kind of single purpose CAM ? There have been a few examples posted in these forums of hemisphere tool paths created without using CAD software.
Page 1 of 2 12
