588,165 active members*
4,600 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 2 issues with Mastercam X4
Results 1 to 6 of 6
    Sep 2008
    11
    I am lucky enough to have access to MasterCam X4 at my school, and while going through some self paced tutorials I have come upon 2 issues that I cant figure out. I would ask one of the instructors if I could catch them around but a lot of times they are not there except for class.
    1. When I try to join 2 entities, I always get an error telling me that the selected entities cannot be joined. for example, If I create a half of a part with a circle in the middle, and mirror it completeing the part, I cannot select the 2 arcs that are generated from this action and join them together.
    2. when creating a pocket toolpath, after selecting all the parameters for toolpath generation and then back ploting the operation, I get an error saying that the profile is not correct, it doesent keep anything from posting, but there has to be a reason it is giving me that error and was hoping someone else may have had the same issue before and could help out.
    Thanks!
    Aug 2009
    106
    Quote Originally Posted by MugenSeiki5T View Post
    Delete one of the arcs.
    Then:
    Edit Menu
    Trim / Break
    Close Arc.
    Jul 2003
    263
    i normaly have this when the T/C planes are not correct
    If you can ENVISION it I can make it
    Jun 2006
    48
    ru still javing that problem or have you figured it out
    Nov 2011
    I had the same problem. You have to first convert all the lines to NURBS then they'll all fit together like peanut butter and jelly.
    Apr 2003
    3578
    Quote Originally Posted by Genopsyism View Post
    You do not want to turn them all into Nurb splines as this would make for more code and need allot of filtering and would not fix the issues.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Mastercam X4 graphics issues
    By PATTSUPV in forum Mastercam
    Last Post: 12-03-2009, 06:46 PM
  2. milltronics rh30 centurian 6 mastercam 9 post issues
    By woody6779 in forum Milltronics
    Last Post: 03-06-2009, 10:57 PM
  3. mastercam 13 post processor issues
    By millertyme in forum Post Processors for MC
    Last Post: 01-05-2009, 10:42 PM
  4. EMC Issues
    By highwaymancnc in forum LinuxCNC (formerly EMC2)
    Last Post: 05-05-2008, 08:49 PM
  5. SL-20 issues
    By 5th-axis in forum Haas Lathes
    Last Post: 12-19-2007, 03:42 PM
