603,796 active members*
3,855 visitors online*
Results 1 to 5 of 5
    2 parts needed: gear and insert
    2 mating parts are needed. First is a gear with a special section cut out in the center. 12 pitch, 20 degree pressure angle, 36 teeth. It should be 0.75 inches thick, 6061 aluminum. See ShockGear.DXF.
    Second part: mating piece which fits inside the slot in the gear. 1 inch thick, 6061 aluminum. 0.75 inch hole with keyway. See shockGearInsert.DXF.
    I'm guessing waterjet cutting would be best, but am open to suggestions. I only need 1 of each, maybe 2 if the price is right.
    Attached Files Attached Files
    Oct 2004
    107
    Do you have the gear stock?
    Gear stock
    No, I do not have the gear stock.
    Oct 2004
    107
    OK. One more question, is the insert share the same face width of .75" ?
    As I said:
    First is a gear [...] It should be 0.75 inches thick
    Second part: mating piece [...] 1 inch thick
