587,881 active members*
4,136 visitors online*
Results 1 to 9 of 9
    Oct 2008
    7
    Red face 2 Pluto-Servo at the same time
    Hello!
    Tell me please, somebody use 2 Pluto-Servo board on one computer at the same time?
    Is It possible?
    How can I do it?
    Thanks a bunch for your help
    Jul 2003
    1759
    2 plutos are not supported at this time. It looks to be possible but would require some development.
    http://linuxcnc.org/docs/html/hal_drivers.html#r1_8_6
    You might want to look at the 7i43 (if you haven't bought the pluto yet) http://mesanet.com/parallelcardinfo.html It is close to the same price and is made a lot better. (although I am not sure if you can use 2 on one computer but it is a lot more flexable - you might want to add what you're trying to do)
    EDIT - I have been told up to 4 are supported of the 7i43 but not tested yet.
    http://www.linuxcnc.org/docs/2.2/htm...ostmot2.9.html
    On a side note - it has been found out that the popular "NetMOS" aka "MosChip 9805" PCI parport cards do not work. They are broken in EPP mode.
    sam
    Apr 2005
    1778
    Sam,
    Do you know if the same bug exists for the NetMOS 9815?
    Alan
    Jul 2003
    1759
    We where just discussing that on irc. I don't know if anyone has tested that.
    archivist, skunkworks: the 9815 hasnt been explicitly tested, but the NetMos/MosChip FAQ said their EPP bug affects all the 98XX chips
    sam
    Oct 2008
    7
    Thanks for answers!
    Oct 2008
    7
    Hello again!
    Maybe you advise me model of extension board PCI to LPT that Pluto works with it?
    My Pluto board works only with LPT port and doesn't work with my extension board PCI to LPT.
    Thanks a lot
    Jan 2006
    58
    Anything that advertises EPP support, and that doesnt use a NetMos/MosChip chip. The chipset is not usually advertised on the box, you'll probably have to look at the board itself and see what it says on the big chip.
    Oct 2008
    7
    Thanks, Seb
    Feb 2008
    644
    Quote Originally Posted by Igor_UA View Post
    Hello again!
    Thanks a lot
    Dont know about the Pluto but it is similar to the 7I43. I just got through testing some PCI parallel port cards with the 7I43. These three cards work fine with the 7I43 and are likely (but not guaranteed) to work with the Pluto:
    LAVA MOKO based (relatively expensive ~$30 but the fastest of all cards tested)
    SUN1888 Based (Startech PCI1P = SUNIX A4008T) ~$20
    OX Semi OXPCI952 based (? rare)
  1. Pluto-P servo Rotates only one way
    By JiriK in forum LinuxCNC (formerly EMC2)
    Last Post: 03-17-2008, 08:14 PM
  2. Pluto Servo - Motors won't servo correctly????
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 01-10-2008, 09:34 PM
  3. Pluto Servo - Any luck with EMC 2.2.2
    Last Post: 01-05-2008, 05:09 PM
  4. EMC2 -- Pluto Servo -- Need Help
    Last Post: 03-02-2007, 08:54 PM
