Re: 2012 TL-1 Won't power up, bad power board?
![Quote](images/misc/quote_icon.png)
Originally Posted by
Tungsten808
Is correct Phase rotation even relevant for this machine? As it goes through a spindle drive and servo amplifiers. Coolant pump is single phase.
What can happen on this machine is the phase rotation is not right? As tested before I am pulling an even 120v from each hot leg to ground so I don't believe I have wild leg setup.
Sounds like you have a 208 volt, 3 phase system. Phase rotation should not make a difference to the servo amps, but you might look at the book to make sure.
Jim Dawson
Sandy, Oregon, USA
