587,892 active members*
4,182 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > 2020 drive with cnc4pc breakout board
Results 1 to 5 of 5
    Feb 2005
    74
    i have a strange problem with the 2020 drives . when i use the tuning software i can get the motors to run well. the parallel cable is connected straight to the computer. when i use the cnc4pc optoisolated breakout board between the pc and the 2020, the motors run very rough and erratic when trying out in mach3. connecting the parallel cable straight from the computer and 2020s in mach3 , they run silky smooth. does the optoisolation not work with the rutex products?
    i assumed that the breakout board would provide a "cleaner " signal for the drives.
    Feb 2004
    466
    This symptom could be a failing ground between the PC and the drive.
    It happened to me a lot when I test drives with just a couple of lead STEP and DIR and if I forget to share the GND the behavior is erratic.
    Konstantin.
    Feb 2005
    74
    thanks for your reply. would not this defeat the isolation?
    Oct 2003
    170
    break out board for 2110?
    Gentlemen,
    Most of the time the break out boards add complexities to the set up. I try to discourage people from using them. The Rutex system was designed to be simple, and it works best when hooked right to the pc mother board or parallel port.
    Tom Eldredge
    Rutex LLC
    Feb 2004
    466
    Well you heard the man.
    I was thinking it too. If the inputs/outputs are all optoisolated then the ground is isolated too. I guess using a wire to join grounds is the way to go to eliminate the erratic behavior. But will it defeat the purpose of having an optoisolation?
    Konstantin.
  1. CNC4PC multi board
    By krymis in forum CNC Machine Related Electronics
    Last Post: 07-29-2008, 01:49 AM
  2. cnc4pc multifunction board Rev 2
    By jguillen08 in forum CNC Machine Related Electronics
    Last Post: 01-14-2007, 04:27 AM
  3. 320's and cnc4pc multifunction board
    By dewme5 in forum Gecko Drives
    Last Post: 08-16-2006, 04:22 PM
  4. CNC4pc Solid State Relay Board.
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 05-21-2006, 09:19 PM
  5. cnc4pc relay board question
    By Stuff-Builder in forum CNC Machine Related Electronics
    Last Post: 03-17-2006, 04:17 PM
